Simple ASP.NET problem
Izi
Izi
9 Dec 2007
PHP:
public void ShowBlackBarButtonsPanel(string panelName)
        Control pnl = this.FindControl(panelName);
        pnl.Visible = true;
The above snippet is my Master Page.
From my page I set
Master.ShowBlackBarButtonsPanel("A Panel Name");
However, I get a "Object reference not set to an instance of an object." error as its not finding the control in my master page.
The panel name defo exists, what am i doing wrong?
I think the panel name will be different from the perspective of the master page.
In each content section the control ids are all changed so that they are unique.
PHP:
public static Control FindControlRecursive(Control Root, string Id)
        if (Root.ID == Id)
            return Root;
        foreach (Control Ctl in Root.Controls)
            Control FoundCtl = FindControlRecursive(Ctl, Id);
            if (FoundCtl != null)
                return FoundCtl;
        return null;
Ok, so I managed to fix this using the above static method:
PHP:
Panel pnl = FindControlRecursive(this, panelName) as Panel;
        pnl.Visible = true;
But i still dont understand why...
if in the masterpage i start writing [panelname][dot] i get all options for the panel name in intellisence.
Thats why with 'this'[dot] should find the control. 'this' refers to the current object which is the master page.
confused.
EDIT: i see what you mean, how do you get around this?
