Simple C switch() statement problem
5 Oct 2003
London
Hi,
Am trying to complete some work for university but have hit a brick wall,
previously in my code i have used a switch() no problem, but now when trying to use the below i get a error C2059: syntax error : '>', & '>=':
Code:
switch (gross_pay)
		case>0 && case<=300 : tax = .15 * gross_pay;
				   		break;
		case>=301 && case<=500 : tax = 45 + .2 * (gross_pay - 300);
					   		break;
		case>=501 && case<=650 : tax = 85 + .25 * (gross_pay - 500);
					   break;
		case>=651 : tax = 122.5 + .3 * (gross_pay - 650);
			    break;
		default :  ;
	printf("Total Tax payed is %d\n", tax);
Can anyone explain why? gross_pay is working fine and its an integral so no worries there, its just the syntax error i can't get around for some reason :(
Any help greatly appreciated.
Hi,
Not 100% sure with C but I don't think you can have switch with that syntax. The case has to be followed with something the switch(variable) can be compared with (matches). Gross pay will be a float of some kind, so the case has to be followed by a float... not the multiple conditions you have tried.
As I said, not the worlds best at C, but that's what I think the issue is.
Yeah - Haven't touched C for a while I'm pretty sure the cases have to be for specific values of grosspay, e.g. case 10000:
You could do those conditions with
if (condition)
else if (condition)
else if (condition)
else
Each case must be an integer constant. So you cant put your expressions there im afraid. Use an if/else if/else structure as suggested to do what you want.
