Hi
I currently have vista 64bit installed, but want to start running XP as it sounds like you can gain quite a performance boost when running games.
Q1: Can I whip out my old HD, put a new one in and install XP, then have both hot swappable when I want to use one or the other. (I've looked at dual booting but seems like more hassle
Q2: Will i gain more performance going to 32bit XP or 64bit XP?
Thanks
Luke
)Q2: Will i gain more performance going to 32bit XP or 64bit XP?
Thanks
Luke
