Simple mapping question HELP
18 Oct 2002
Manchester
my wife has set up a shared folder on her laptop computer name is Amanda and the drive is D how do I map my this drive so I can access it on the main pc I have a wirless network
if someone can provide the path command I would appreicate it have tried to figure it out using Windows help files but it wont work
:confused:
In My Computer, you choose Tools | Map Network Drive.
To do it from the command line, you use net use. net use /? gives more info, but the syntax is basically:
net use X: \\computername\share
just remember if you need to enter credentials its
net use X: \\computername\share /user:username password
