Simple maths question
SO YOUR TELLING ME the you have the base length and the angle, you cannot draw it? as the angle on the right matches the angle on the left, draw a line on each side till they cross measure line.
Do you not think it might be quicker, easier and a bit more accurate to simple calculate it?
It's impossible for it to be right angled if two angles are the same, in which case SohCahToa doesn't work. You have to use the Cosine and Sine Rules.
You can just split the triangle down the middle to make two right angled ones.
See my post above :)
I love it.
Throw some basic trigonometry to the geeks and watch them squabble over it. It's like bum fights for the socially challenged :p
Ant :cool:
