Simple overclocking guides?
Increase the clock speed in the bios by around 200mhz at a time. Reboot and see if it starts, do this till it won't boot. You'll need to take the motherboard battery out for 10seconds to clear the bios if it won't boot. Then drop the MHz by around 200 at this point and reboot.
Then monitor the temps from windows. Shouldn't be more than around 70degrees.
You can increase voltages also but I find it's usually not needed for small over clocks.
I got to 4.3 ghz
It gave me a few more points in 3dmark and cinebench went from 6022pts to 6809pts
But I was a little confused because the 3dmark shows
Reported stock core clock
3,800 MHz
Maximum turbo core clock
4,591 MHz
Changing the cpu multiplier I'm fixing it a 4300 Mhz
So is it worth the over clock
So you couldn't get past 4.3ghz? Not sure how the turbo works with an oc.
windows failed to boot with 44. Not touched voltage or anything else
also adding about 139mhz to gpu clock speed according to msi afterburner
will run 3D mark once more with both these overclocks
What are you finding that you are doing that warrants wanting to overclock the CPU out of interest?
I run batch operations and process images in lightroom with simultaneous photoshop usage.
If I could get more worthwhile performance out of the CPU then it means I can clear jobs quicker.
December will be a very busy month, and work may start cutting into my sleep.. it'll be a step up from my 6700k anyway.. though that was overclocked to 4.7ghz
Shortening things like the export time, render time as I zoom through images.. all help
