I've used seagate diskcheck for psychical errors which lasted around 45mins that passed with 0 errors however when using seagate filecheck tool i got this:
Some files of the volume are open.This may effect the accuracy of the file system check and result in false errors.
The file system contains errors that need to be repaired.
Now i know diskcheck could solve this but does anyone know a good programme that could help? when i try to use windows diskcheck it says:
cannot access volume for direct access
Then it just stops doing it and loads up windows.Is there a way to solve this?
Please help, thank you.
- hint hint - and then replace it.
