Permabanned
- 10 Nov 2010
- Disneyland
Would i see a big difference if i upgraded from a Q6600 @ 3.2 with 4 GB ram to an i5 2500k with 4 GB ram for gaming?
depends what your graphics card is. the Q6600 @3.2 is still a resonable processor (equivilant to the phenom II X4 955BE @stock i believe).
so, if you have a completely poo graphics card, you'd be better off upgrading the graphics card. if your graphics card is really good, then the processor upgrade would give a good increase in gaming performance
At stock speeds there is quite a difference between them, would you OC the 2500k as well?
http://www.anandtech.com/bench/Product/53?vs=288
I'm thinking of getting an overclocked bundle @ 4.6.
Bumping this thread up as i need more advice ?
What do you currently have? What do you need? Budget? Main use of PC? When are you planning on buying?
Like I said, some games benefit from a faster processor:
Far Cry 2
and some don't:
Battlefield Bad Company 2
So the anser to the question "I was just wondering if i got a 2000k bundle @ 4.6 if i would see a big difference?" is sometimes.
Would i be better off spending my money on an SSD and another 5850 in Crossfire?
