single card solution equal to 6870's in CF
17 Oct 2010
Welling
What would give the equivalent power or slightly more power than my current setup?
I'm either going to sell both cards and get a single card solution or i'm gonna upgrade the coolers and clock them. what would be the most cost effective cooling solution for these cards?
thanks for you input!
I stick with what you have for now, if your not having any problems that is and just overclock them, both of mine run at 970-1200, haven't come across anything they can't play on max details yet.
if i keep them then they'll need better cooling as they are standard reference cards.
if it costs me £70 to upgrade the cooling on them then if i sell them and add that £70 to it then i probably end up with approx £250. i'd only need to add £50 to that to get a 7970.
dilemma!
dilemma!
Why on earth would you bother with all that when you can get the twin frozr 7950 for £250?
