Single drive on an array controller
30 Nov 2003
I've used up all my IDE channels but my motherboard has an onboard highpoint raid controller. Is is possible to hook up a hard drive to it and run it as normal?
I connected it up and the controller detects it but it does not show up in windows...
In the bios there should be an option marked configure sata devices as raid/ahci/enhanced ide. Any chance its set to raid?
When you say it doesnt show up on windows, is this a previously formatted drive or a blank one? Does it appear in Disk management [run compmgmt.msc to find this if in doubt
If its either of these then the fix is quick and easy, otherwise I wish you luck
