Single partitioned drive Vs. Multiple drives
14 Jan 2004
Reading, UK
Hi all, just a quick question; is there any operational/performance implication for having two separate drives (one for OS, one for storage) as opposed to a single drive partitioned into two pieces?
Indeed, one hard drive with two partitions can still only read at the speed of the drive, say 100mbps. If you have something you want from both partitions, that means that the data ll has to fit down one 100mbps cable.
If you have two hard drive instead, you have two 100mbps cables.
I have four drives with various things on each, wouldn't even think of going back to a single drive, a 2tb would be the same as what I have in total now, but I have the option of backing things up, extra speed, easier reinstalls etc etc.
A drive can only do one thing at a time so if you're using it for everything it gets thrashed like mad, even a some slow downloading can cause that. More drives the better.
