Single Speed MTB
SpeedFreak said:
erm no they don't. It may be a term used, but chains do not strect. Yes you get cog wear and yes you get chain wear, and yes this gives the perception of stretching, but pin to pin distance does not increase :p
no **** ;).
How come to tell if a chain has stretched you measure 12 links.....and if its longer than 12" by an 1/8th of an inch its stretched. Thats what ive been told anyway. :confused:
Sorry...depends on the terminology you use for something getting longer :o
Been very tempted to go for SS, borrowed one for a couple of 24 hour races a while back it its mental! I'm rubbish at climbing and SS just forces you to boot it!
On the topic of fixed wheel, I had a quick play on a mates after a skinfull on Friday night, that was enough to convince me its a bad idea.
No. YOU are mental :eek:
A couple of my pals are doing the Strathpuffer 24hr, I sort of wish I had a second bike to be able to do it. Well that's my excuse. :o
