six axis controller
20 Mar 2005
Leicester
Mine has just broke :( the spring on the R2 button has snapped.
Time to buy a Dualshock I guess, but anyone know where ya can buy the springs at all? looked on the bay but refuse to pay 10 quid lol
nope none on there, I have my dualshock now, but will keep an eye out for busted ones to salvage from :)
The Button still works it just wont spring back into place so is useable but annoying
that happened to mine but i dont know how the fix it... its just really sensitive now since its neutral position is half pressed... waste of a ds3 (white one too!) :(
i was just about to suggest using one from a old ps2 pad but then i realised how stupid my idea was :o
i think the best thing you could do is just sell your remaining good spring for a tenner and at least you have some of the cash back from buying the new pad :)
Has the spring definitely snapped? Or has it just pinged off? I had a PS2 controller where the spring became dislodged. Took it apart and fixed it easy enough. :)
yeah its snapped, it went loose so i opened the controller up and it fell out in two parts :D Ill keep an eye out for a spares or repair one.
Like I say its still useable so will let my mates use it when we play multiplayer. Handicap pad :D
I know nothing about the interior of pads, but what type of spring is it? Surely just buying a reasonably sized spring at a DIY shop and cutting it down to size would do the trick?
A model shop may be a better bet?
Got any local shops that do RC stuff?
Meh, take the spring/pad into a model shop like JUMPURS said and see what you get out of them. Can't go wrong if you can repair a £30 pad for a couple of quid and a bit of effort!
