I'm trying to make a model in sketchup. or would a different program be better for this?
and although I've done a few basic things, pushing, pulling and cutting.
I just cant get to the next stage and no tutorials I've found have helped.
and wondering if any one can help me or show me relevant tutorials.
probably better one or two question at a time, as there's a huge amount I cant do.
but basically I'm trying to model a planes wing, then hollow it out, apply openings and internal support sections. then slice it into several separate parts. So it could be 3d printed then slotted and glued back together.
can you, or is there a plugin that can draw a shape using a list of coordinates?
and how would the best way to create an object that changes shape in all three axis, as cutting and pulling is two dimensional? or what's the best way to get that shape precisely into sketch up?
I thought maybe crating a shape that runs through the centre of the aerofoil, then making and resizing the aerofoil and placing them along the shape at regular points, then somehow connecting it all up to make a solid shape?
so trying to apply this to make a tapering wing
