Is it possible to order the above without the Sagem router? I'm hoping that existing hardware (NETGEAR DG834G) can be utilised and the £75 setup fee reduced.
Thanks in advance!
If you mean can you use your own Netgear router then the answer is yes - but Sky will tell you otherwise. The information for getting your username and password is available on the net
QUOTE]
I mean, if you already have your own kit then will they supply the service without hardware and reduce the £75.
Yeah, I doubt it![]()
I thought you only paid the setup fee if they had to come and do it
Thanks in advance!
its not possible to have the £75 fee waived as they officially only support using their router.
They dont want people using their own routers, which is why usernames and passwords are hidden in the firmware. So if you're officially not supposed to be using your own, theres way there going to give you a discount to do it![]()
