The HD subscription is an extra £10 a month, I'm not sure if that's per box though.
I have just logged into Sky to check upgrade prices.
This is what options it gave me for replacing my standard box.
Also, the Sky HD subscription is £10 per box.
You only get your first HD box free.
Well work your magic bevysters!![]()
order a sky+ box online and chances are you get a HD box because no new sky+ boxes are made anymore so its a cheaper way to get your 2nd hd box instead of paying full price. Plus it means your not tied to the HD subs on that box for a year.
That would be quality receiving a Sky+HD box when ordering a Sky+ box! With my luck though, that just wouldn't happen lol.
I have one of the first Thompson SkyHD boxes, and its on its way out. The common no satellite signal is being received error, although the dish is aligned correctly, no water ingress in coax etc. A restart of the box resolves this, and its apparently a power supply problem.
I definatley want to get one of those 1TB boxes though!![]()
If its booked as multiroom then you would get a free install and a free service call on your old thompson box if its all booked right.
As far as the sky+ thing goes. Its more than likely you would get a HD box because we keep the sky+ boxes for accessability customers because the old software and menu makes life a lot easier for them.
I have oneJust looked at the Sky+HD 1TB box, that looks the nuts!
Cheers for the info!![]()
The cloth is for cleaning the dolphinThrow that dolphin away and start using that cloth!![]()
eeeee, I didn't know there were all these options :s It would be just my bedroom standard sky plus box that would be replaced, not the other 2, Id just like the same box basically but HD if that makes sense...We haven't been offered a free replacement, but am I right by saying from what I've read you get your first HD box free? So therefore I'd just be paying for installation and the £10 a month subscription?
