Ive downloaded the demo hdtv clips from http://www.sky.com/hd/
there are a 4 clips 2 download it looks amazing on my 43" plasma wow
does this mean sky hd will be better than wmhd?Sclodion said:Bear in mind these are WM9 HD encoded @ ~10 mbit and as such cannot actually be taken as truely representative of the quality that Sky will be broadcasting their HD content at, which will be MPEG2 not MPEG4 or WM9, somewhere between 10 -18 Mbit variable rate, depending on the value of the content.
philhoole said:Sky will broadcast HD in mpeg4/H.264
Sclodion said:How the hell did I miss that... I work with a lot of US broadcasters who are all doing HD with MPEG2, completely passed me by that the HD from sky would be MPEG4 AVC, although I will be very interested to see if they actually are going MPEG4 from the outset as there are very few real time HD MPEG4 encoders on the market at the moment and those that are there need a lot of work to be as good as their SD counterparts.
Attu said:MPEG4 is aparantly also one of the reasons why Sky HD has been delayed as there is a world wide shortage of the chips, as far as im aware its imposible for them to start using MPEG2 and then swap over to MPEG4 without replacing all of their equipment including the Sky HD boxes in peoples houses.
This I belive it the situation the US broadcasters are in at the moment, they started using MPEG2 but are now migrating over to MPEG2.
Sclodion said:No PC processor on the market today can do HD MPEG4 decoding on its own. It can be done with the assistance of hardware mpeg4 decoding on the gfx card but you're looking at £3-400 worth of processing power to do it with PC bits, minimum.
Energize said:My graphics card has no mpeg4 decoding hardware on it afaik and I can play 720p video fine on my athlon 2600 at about 70% cpu usage. My cpu only cost £60. So there should be no reason for a sky box to cost the estimated £400.
I'd love a nice loud fan in my set top box as well.Energize said:My graphics card has no mpeg4 decoding hardware on it afaik and I can play 720p video fine on my athlon 2600 at about 70% cpu usage. My cpu only cost £60. So there should be no reason for a sky box to cost the estimated £400.
Sclodion said:Think you got the wrong end of the stick there mate. A dedicated piece of silicon is always going to be cheaper (and better) than a generic processor at a specific job, hence an HD decoding FPGA costing a lot less than a PC processor, but being far better at the decoding job. So no, a set top box will never cost anything like $400.
Of course, that PGA can only do that one job, wheras a pc processor is designed to be a generic workhorse.
But the point is that the $50 FPGA will be better than the $400 PC setup at decoding HD as that is solely what it designed to do.
Caged said:I'd love a nice loud fan in my set top box as well.
You can barely hear the media center in our front room when the tv is off.Raider said:When you play these Hi-Def clips on your PC, do you use any software? Or just WMP?
