sky modem wifi signal
7 Sep 2009
London
Hi I've got the old netgear DG934G router (black) and have moved from a flat to a semi. The BT line is downstairs in the lounge. The study is opposite side of the house upstairs 1st floor.
The PC and PS4 struggle to get a signal sometimes- Max 600kb down. I don't want to spend a lot of money and was wondering if the SR101 Hub is worth upgrading to for wifi signal - any experience?
I was thinking getting it second hand off gumtree. Alternatively, is there a cheap router I could purchase that might sort my issue? Though tinkering around to get the sky broadband to work is off-putting.
Thanks:rolleyes:
Have you tried changing the wireless channel at all? If you have android download wifi analyzer and see what's happening with the channels.
Your router is wireless 'G' whereas the Sky Hubs are wireless 'N' so theoretically you should get a better signal, further with one.
yeah tried all that
also positioning router
thanks
The SR101 and SR102 aren't the best for wireless signal or speed. I personally use a Time Capsule as the wireless access point and have the wireless switched off on the SR102, which means you don't need to mess about with getting details (which I have anyway :p) or trying to make a 3rd party router work.
Going that route would give you better results for less hassle.
Except a time capsule is £250!!
You don't need a time capsule if you don't want or need the NAS functions. TBH you could use any router, turn DHCP and the wireless off on the hub and connect everything to the other router. Or buy an AirPort Extreme.
To be honest id either get a wireless extender or if you could run a cable get a wireless ap, the new UniFi ones look great waiting to get some in to play about though.
You're never going to want to be using Wireless for gaming, although if I had to Id want to be using AC on an AP. Although to be fair Id just run a cable, couple of cat5e will do.
Yeah I know WiFi isn't ideal.
Would love to run cables but it's literally other side and would be very difficult to hide them going through lounge upstairs across hall into corner of room
Wireless for gaming is OK if you have no interference sources, a good signal and a clear wireless channel to use. I've been gaming wirelessly for years without any real bother.
Bought the sr101 hub £10 second hand. Not amazing improvement but just enough to stop the disconnects. It will do for now.
Thanks for the tips!
I've run Ethernet from my computer room upstairs to outside the house, around the back, then back into the house downstairs behind the TV to an 8 port switch. then all boxes\TV Ethernet connected and an Asus EA-N66 wireless extender for WiFi. Works a treat. Strong WiFi all over the house and garden. Sky SR 101 Wifi Switched off. It was useless.
