Sky Multiroom with sky+?
23 Feb 2004
Brentwood, Essex
Hi,
Im looking at getting this done so I can have sky+ in my room so I can watch the sport etc.
Now I know its £10pm ontop of the main subscription but do I pay another £10 ontop for the sky+ subscription?
also could I buy the sky+ box off ebay and also the quad LNB and cable or should I leave that to sky?
Also whats the difference between all these sky+ boxes and which is best of them, I dont need the 160sky box as I wont record that much?
cheers
if you have sky sports world/sky movies world/sky world packages then the sky+ cost is included.
With regards to buying the sky+ box on ebay, thats what I did. Box was about £120 (pace v2, last april), LNB about £15, cable (the 'shotgun' ct63 coax) 75p/metre, then you only need F connectors for the cable (cheap) and self amalgamating tape to waterproof it all.
Best sky+ box really is a pace, avoid the amstrads and try to get a v2 box wherever possible.
ok whats wrong with v1 and v3 pace boxes?
Also do skyboxes support component out?
thanks
v1s are a bit old.
v3s are fine (80gb hdd in them) but if you don't need that hdd then i'd get a v2 as they'll be cheaper.
No component out :( best bet is rgb scart.
I already have Sky Multiroom, but not Sky+. Are you saying I could buy a Sky+ box for one of the rooms and rig it up myself, without paying the Sky engineers a dime?
unless you want fringe reception an LNB is an LNB really. On ebay raven ones go for under £20 new, not the best quality but they do the job fine.
I think I will go the raven ones on ebay, what cable would you suggest for the dish to the box?
CT63 shotgun or some WF100 cable or maybe ct100?
how long is the run?
WF100 is the dogs ********, iirc its foam insulated so pretty good (less chance of water getting down etc).
Advantage of ct63 is that it'll fit through a hole where 1 bit of coax would fit before, handy if you only want one hole. Disadvantage is that its not screened as well so anything over 20m for a run and you'll come across problems.
www.satcure.co.uk is a good site with excellent service, some of their stuff is a bit on the pricey side compared to trade sources but i've ordered from them before and had the kit with me about 14-15 hours later. (don't think they're a competitor...).
Make sure to buy F connectors and self amalgamating tape too with the cable, and remember that ct63 uses smaller F connectors than normal coax.
Id say the run is about 20m may be more or less.
20m is fine for it (my cable is 22m and I don't have problems).
sky+ with free fitting for £89? that for a new customer or existing? Damn good deal if its for existing ones too :)
Its existing I'd thought, well I am gonna get me mum to upgrade to skyports pack of 1,2,3 and extra,
but thats just with standard Sky+ not the 160 which is £199 option, I surpose if sky fitted it they would use ct63 cable? or could I ask for wf100 which is what i have on my aerial cable?
thanks
