Sky / TV card?
24 Nov 2002
38.744281°N 104.846806°W
I'm thinking about getting a basic £15 Sky subscription for my room as I don't have a decent aerial for freeview......
Now, do I need a tv card (to connect to the sky box) for this? Or would my x1900 VIVO suffice?
:cool: Hi,
Im not 2 sure about your setup, but I used a cheap pci tv card and ran a cable from my sky box second ant/out (RF2) and then tuned the card in and it work fine. :D If you are wanting 2 use sky on your pc in a different room 2 your didgi box then you can use the sky tv link kit, however you still need to feed the cable from sky box 2 pc.
Dont use a transmitter kit as it seems 2 mess the signals up after abit.
Hope this helps abit, any probs just let me know ;)
Well, as sad as it is I'm getting Sky just for my room... so the box will be next to me.
It is either new aerial + freeview pci card, or card + Sky.
Not sure which'll be best.
My monitor takes composite in and I have an extra L/R phono input on my speakers so I can use a scart -> phono to plug it all up to watch without pc booted. Then I can run the rf to the pci card and tune that in to watch when pc is on...
That sound right?
:cool: Hi,
If you are having sky box in the same room then that will make things a whole lot more easy, just link the sky box 2 your tv pci card and then tune it in, once you have done that the tv card should pick it up as a normal tv channel and that should be the end of the install side of things. :)
Then all you need 2 do is sit back and enjoy. ;)
All he needs is to plugin the sky box via composite if I understand vivo correctly.
