Surely trying it out would have been quicker?
In some scenario's, maybe it's not!![]()
Not if it killed my phone by trying it wouldn't.
If it's USB then it's not going to output more than 5v on the power wires.![]()
Yes the port is a USB port but if might not be using the USB standard for wiring/voltages etc...
In which case it isn't really "usb" and they wouldn't put a USB port on it that was non-standard.
If it's a USB port then it's got to abide by the USB standards.
They don't, they're just not enabled. All that's on the USB ports is the +5V. The actual data is disabled. PS3 controllers etc require active USB ports.So whatever the 'standard' states, these boxes adhere to different versions of it.
You can use it to charge things up, it will output 5v and I use it regularly to charge up my phone.
