Skyrim bug
25 Jan 2009
East Kilbride, Scotland
Hi, ive been having a bug where black lines will go across my screen, you can also hear a static noise. Its as if im underwater, it only happens sometimes and when i look directly at the sky. is anyone else having this problem ?
Thanks
its just a bug. i thought it may have been to do with the grpahics cards but it just as if the ground is water. its weird. Drivers are up to date, just slightly below ultra settings and 1920x1080 res.
The game is using all four cores nicely here.
just what i was reading mate im no expert at this.still learning..
this game is doing my nut now i wont be playing it again till its sorted the fps drops are too drastic for me to enjoy the game...
I would really like to sort this out as well, it is playable but annoying.
Outside cities no matter how much is going on on the screen i get 60fps constant(with vsync on), likewise anywhere indoors, but in cities any places with buildings it can drop as low as 20fps.
I fought the first dragon getting 60 fps with no dips with loads going on on the screen, then returned to Whiterun and was getting 25fps:confused:
6950 2gb
965be@stock
6950 2gb
965be@stock
same, i was near 100 fps on the dragon fight then down to 40 in whitefall.
I also have this static noise in game. Turning down the "effects" slider to about halfway makes it better.
