Sli 7900 clocks
5 Jul 2005
Edinburgh
Just wanted to check that this is correct: When running sli the cards dont have to be identical - just 2 7900's are fine. But what about the clocks of each card. Cna you still ovetrclock each card seperately and do both cards have to run at the same clocks?
I used to have dual 7800GTs, one was a BFG OC and the other a standard ocuk one.
Both cards operated at the speed of the card in the blue slot, which was the BFG in my case.
Worked fine although it ran the standard card at the BFG overclocked frequencies.
Coolbits clocked both cards together.
