- 12 Oct 2010
Hi
Im trying to figure out which SLI motherboard to buy. My aim is to have 2 MSI GTX 768mb 460s running. Ill have one next week than another after Christmas. A few questions have me stumped
Firstly..
On most motherboards ive seen it seems that if i ran two double sized cards they would cover the other PCI slots. Where would i put a good sound card which ill also be buying?
This will be going in a Silverstone Lascala so plenty of space for ATX. Also, what i have now is a Q6600 so it will have to be compatible with that
Whats the best midprice 2x or 3x way Motherboard out at the moment. Hopefully between 100 - 150 but could increase if necessary.
3rd slot would give me better choice with the soundcard but not absolutely necessary
If you need any info just ask
Thanks in advance
Firstly..
Thanks in advance
Not sure that is a problem for the original poster.
