Yep, pastymuncher had suggested the pro gamer. A two slot gap can make quite a difference with non ref cards. Prior to moving to Z87, i ran sli windforce 670's in a two slot gap Z77 asus v pro. The cards ran a bit cooler than they did when i switched to the Z87 board in sig.Or the Asus Z97 Pro Gamer.
Alpenfohn k2 with dual corsair sp 2350 rpm PWM fans.What cpu cooler are you using setter ?
Only one slot, hero has the same spacing as the formula which I've had sli cards in.Abit confused what the problem is,, Maximus looks to me like a two slot gap aswell.
