SLi Setup
13 Jun 2005
West Midlands
Right, Ive setup my 2 x 7800GT's for SLi.
Now how to test them and what should I be looking for when testing them?
Do you mean rough benchmark scores?
If so I would say you should be aiming for 11k+ in 05 24k+ in 03 and 5.5k+ in 06.
Most games apart from oblivion should run maxed out (from what I have seen the 78GTS just don't like oblivion on max settings).
Hope that helps a bit.
Ah right cheers. At least I know what Im looking for now.
Ill be maxing out the likes of DoW and WA and also RoL as well.
One of the lads from work was telling me that SLi makes the most difference in an FPS. Is this right?
Certainly does. RoL is so CPU limited you won't get much advantage from SLI. You'll be able to max out things like FSAA though with no FPS drop. Other CPU intensive games (RTS, Flight Sim) also won't show much of an improvement with SLI.
