Page 1 of 3 1 2 3 >
Showing results 1 to 25 of 75
Search took 0.33 seconds.
Search: Key Word(s): sli, problem
Results 1 - 10 of about 6,590,000 for noobs. (0.04 seconds)
- shouldn't really happen in this day and age except due to user error, tho does apparently happen with crossfireX using more than 2 cards or 2 cards of different specification.Even with two cards some games actually run SLOWER than with one card.
I find my XFX 780i board is excellent...very stable and overclocks very well....I only ask becuase I am hesitant to get an nForce 780i instead of the seemingly trustworthy Gigabyte due to the reviews not being very positive in terms of drivers etc.
whether you need SLI or not... I don't think I'd wish an nForce 680/780 board, especially asus on my worst enemy...
So, as someone who's got SLi mate, what games you usually play and what res etc etc? My games are... running in res's...
Crysis - 1920x1200 0xAA, 0xAF VSYNC off,
Bioshock - 1920x1200 2xAA, 4xAF VSYNC on,
Dirt - 1920x1200 0xAA, 0xAF VSYNC off,
UT3 - 1920x1200 4xAA, 8xAF VSYNC on,
UT2004 - 1920x1200 16xAA, 16xAF VSYNC on,
My reason for getting the extra card is so I can run vsync on Dirt and any other games Crysis, being the exception maybe... UT3 looks stunning and runs like a dream, no tearing etc, where'as Dirt has some tearing and it's not 100% smooth, playable no problem, but not perfect and hoping the extra GPU would solve this.
What 8800's are you running and CPU mate?
Cheers
Pug
I've got SLI'd 8800GT's and see a decent performance boost gaming at 1920x1200.
Performance can be worse at lower resolutions, due to SLI overhead, but if you're gaming at low resolutions then there's not much point in considering SLI. The real performance gains are seen at high res with lots of AA/AS.
Boost yes but is it any better than buying the better single card for the price you paid for 2 x 8800GT?
Nope.
Yes.
It cost less and gives better performance.![]()
a 3870x2 costs £223, 2 x 8800GT costs £223
Throw in the extra costs of a SLI mobo (which aren't some of the better boards for overclocking and getting the fastest out of your cpu) and needing a more powerful psu to run 2 cards, extra aftermarket coolers/waterblocks x 2 if going down that route, more heat to get rid off if not so I am been more than fair in saying that they both cost the same when you could argue the single card 3870x2 is cheaper.
Easier to overclock a single gfx card and you will acheive a higher overclock than trying to overclock two cards in SLI.
Add the hassle of getting SLI to work in some games etc but that's just a side gripe and nothing to do with performance so I will move on.
The 3870x2 will outperform the 2 x 8800GT in games with all the added bonus of what I have said.
SLI does have it's place. If you already have a SLI board and you get offered a 2nd matching card to yours on the cheap then yes, worth doing it even with the downsides.
To actually go out and spec up a new system with an SLI board and 2 gfx cards is a waste of money IMO and a non SLI board, lesser psu and a single card will always be the cheaper and better choice.
Just to qualify the Custom PC results a bit, they were only measuring the MINIMUM frame rates, not the maximum, which is why they were reporting minimal increases with 2, 3 and 4 cards or even drops in some cases.
Their view is that minimum frame rates are the ones you notice, especially when they drop below 25fps, so they concentrated on those.
To be fair to them, I noticed minimum frame rates dipped slightly in some games when I had SLI 8800GT's, although I still think some of the conclusion they drew were a bit flawed.
Maximum and average frame rates were rather better in almost all cases, as the minimums they recorded may only have been for split seconds.
