sli, xfire? basic help please
Permabanned
26 Aug 2009
im looking at building a new gaming rig soon however the latest when i was building these was agp 8x, now i see there is sli and xfire, whats the diff and are they really worth it and needed to get a decent spec machine?
SLi is for NVidia, xfire is for ATI, it allows you to use 2 cards in conjunction to boost performance
but no its not necessary and in fact the best advice is when building a new machine get the single best card you can afford, if you think you might need more power later then get a mobo and psu that would allow for additional card at a later date
not all boards do both xfire and SLI, some do only one or other, some older boards dont do either but Im not aware of any new boards like this, just make sure when you come to buy you dbl check everything or even do a spec thread in here
or in the case of i7s and i5s both.
Just to make it really confusing though there is an i7 board and I imagine there will be some i5s that are just ati.
