Slimline cooler required for ML02
29 Oct 2005
Newcastle upon Toon
Hi all. :)
I need a whisper quiet HSF for my Silverstone ML02/Core2Duo rig. It needs to be very slim (well, not very tall) as the case is very slim, and it also needs to be able to cool a Q8200.
Silence is the main driver for me.
Any thoughts?
Cheers
M
according to the silverstone site your max cooler height is 37mm :( your best option may be one of the copper 1U server coolers but they aren't exactly quiet.
Hmmm - thanks guys.
I've had a good surf about and cant find anything suitable. Looks like I may need to keep it dual-core. I have the silverstone cooler and its ok, but its still a wee bit noisy - might have to see if I can mod something up. :)
M
you could lower the voltage slightly and underclock it slightly?
i take it you are using the 37mm silverstone nt07-755 cooler at the moment?
What i found worked great on my e8500 was the old stock intel thicker cooler from there 65mn CPU's
thin
Thick
Yeah, that's the feller... not the quietest i've ever heard, always seems to have a consistent level of noise as if its not accounting for temperature.
