- 20 Oct 2019
I am aware that powerline adapters are not as fast as ethernet cables. However despite upgrading to a 300Mbps internet package the devices that are connected to our router are not recieving very much bandwidth. The image linked below from my google drive shows the results of a speed test done on my pc which is connected to a powerline adapter. It also shows the bandwidth between the powerline adapters in TP-link's software which is far higher than the speed test. Devices connected directly to the router via ethernet will recieve speeds above 300Mbps. I have changed out all the ethernet cables across the network to make sure none of them are faulty or have low bandwith. I have also tried removing every device from the network other than my PC. Can somone explain to me why this is happening and if possible how to fix or mitigate this issue. I apologize if i am just being stupid.
https://drive.google.com/file/d/13ompD_CVy2wSxz1eZswizacGX-PgUFM0/view?usp=sharing
As mentioned earlier, a network diagram would help us to help you, but removing powerline will almost certainly resolve your issues.
