- 14 Oct 2007
- newcastle
I just checked the exchange and BT is reporting no VP issues, so it's looking even more likely to be an ISP issue.
I would not even bother looking at your cabling - you are syncing at full speed for your ADSL mode with plenty of SNR margin. No amount of fiddling with cabling, removing bell wire or using test sockets will help you as they all fixes for improved sync speed, which in turn increases throughput - you simply can not sync any faster.
I would agree have you excessively downloaded in the the last few days?it would explain why you look like your being throttled(when I was on sky connect even though I had 40gb download allowance if I downloaded more than 1.5gb a day they would throttle me to death)
