Slow Pentium 4 Machine - Advice
18 Oct 2011
Hi guys, I've got a machine downstairs of which is about 9 years old and is incredibly slow in terms of boot up etc, I've run Ccleaner and various other applications but none seem to improve it. I've looked for a windows disk to do a fresh install but due to it being a retail machine it dosen't have one (or its lost lol). It is old in terms of hardware, but why throw away a working machine if it needs a bit of tlc, It's mainly used by the family for browsing, flash games. (Back in the day I use to do raiding on it too lol)
Another major problem is the sheer sound of it, it's like a jet taking off and I'm not over exaggerating. So I'm thinking of trying to get hold of a heatsink to shut it up a bit :)
Specs are as follow:
Mobo - Intel® Desktop Board D915GAG (LGA775)
Cpu - Pentium 4 @ 2.8Ghz
Ram - 4gb
gfx card - Geforce GT220
Psu - cheap unbranded 300w
Cheers Sneak :D
In the search bar type msconfig which will bring up a list of programs that run at start up. Uncheck the ones u dont need to run like adobe, java, etc and restart.
Should help a little.
Clean and reseat the current heatsink would be a good shout.
9 years of dust will probably have taken its toll, might be throttling down.
Windows reinstall would be worth it also.
Good idea actually. I was just thinking if the heatsink/fan is knackered from the extensive use throughout the years. I'll try that and see how it goes!
