- 4 Dec 2007
- hull, East Yorkshire
It arrived on wednesday and I was a bit shocked at how big it is, this is without doubt the largest case I've ever had, so it should last me quite a few builds I reckon.
Took it apart and noticed that despite having the holes in the motherboard tray, that all the wires would have to go through a hole above the mobo, so they'd still be visible really. Cue a trip into the garage to play with the power tools...
Cut a rectangular hole in the upper side section so that the wires can do this,
This way any unused cables I can tie-wrap up at the side of the psu, the only part of the 24-pin cable on veiw normally will be a little bit at the plug (same with the 4-pin power cable, routed behind the mobo), and the cables for the drives can go behind the top section straight into the 5.25" bay.
Need some braiding for the front panel and fan cables, but should look nice and tidy I think.
(please excuse the poor camera-phone pics and the old psu)
looked great at first but the mb tray was out quite a bit and when trying to install my graphics card it was a nightmare in end took all stuff out. cant be arsed to send it back either as weight / cost time of year/ messing about.
