Ok, am at work and been given a task I'm struggling with.
We have 4 CCTV cameras at our work which are linked to a DVR and networked so you can access them from a web client using a username and password.
Now, on any PC using Windows XP I can open up internet explorer, add the IP address of the main CCTV unit to the security exceptions list, enable activeX for that site, and it will prompt me for a login and I can get access no problem.
However, when I do the same with a PC running windows 7 it pops up an error saying "failed login" even although it's the same username and password I used to logon from the XP machine.
As far as I can make out the CCTV system uses EnNet software and CMS to control the cameras (if you don't want to use the web client), but I can only find EnNet 2.5 online and can't get it to connect on either XP or Win7. Any thoughts peeps?
