Small form PC - gaming and browsing
22 Oct 2008
Lisburn
Product Name Qty Price Line Total
MSI Radeon R9 290 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card Card £249.95
Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail Retail £191.99
SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £62.99
Asus H81I-Plus Intel H81 (Socket 1150) DDR3 Mini ITX Motherboard £58.99
Crucial BX100 120GB SSD SATA 6Gbps 7mm Solid State Drive (CT120BX100SSD1)
£53.99
Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) HDD £41.99
TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD38G1600HC11DC01)
£39.95
Cubitek Mini Center Mini-ITX Case - Black Cubitek Mini Center Mini-ITX Case - Black £37.99
Alpenföhn Panorama CPU Cooler Alpenföhn Panorama CPU Cooler £19.99
Sub Total : £631.52
Shipping cost assumes delivery to UK Mainland with:
UPS Access Point Ex.VAT
(This can be changed during checkout) Shipping : £8.00 Ex.VAT
VAT is being charged at 20.00% VAT : £127.90
Total : £767.42
Sorry in work and can't use backet thingy
Would this all fit in the above case?
It's for a mate. He'll be connecting it to a 42inch TV.
Any improvements that I can make to it? Anything better in terms of components?
As I said it'll be for gaming, watching media and browsing.
He doesn't need a Screen, keyboard, mouse or OS
Not sure about the gfx card.
Is this the case? - http://www.cubitek.com/products/mini-series/mini-center
Maximum Compatibility VGA Max. 180mm long
CPU Cooler Max. 85mm height
Not much room at all.
And a "K" cpu is wasted without a Z chipset board.
Does he want a really small case like that or would this cube do?
YOUR BASKET
1 x Asus Radeon R9 290X DirectCU II 4096MB GDDR5 PCI-Express Graphics Card (R9290X-DC2-4GD5) £229.99
1 x Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £191.99
1 x Gigabyte Z97M-DS3H Intel Z97 (Socket 1150) DDR3 Micro ATX Motherboard £74.99
1 x Antec TruePower Classic 550w '80 Plus Gold' Power Supply £53.99
1 x Samsung 120GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E120B/EU £53.99
1 x Antec ISK600M mATX Cube Case - Black £49.99
1 x TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED38G2400HC11CDC01) £47.99
1 x Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) HDD £41.99
1 x Raijintek Aidos Direct Contact CPU Cooler - Black £14.99
Total : £759.90 (includes shipping : Ex.VAT).
He should consider getting a 250GB SSD.
YOUR BASKET
1 x Gigabyte GeForce GTX 970 WindForce OC 4096MB GDDR5 PCI-Express Graphics Card (GV-N970WF3OC-4GD) £269.99
1 x Intel Core i5-4460 3.20GHz (Haswell) Socket LGA1150 Processor - Retail £154.99
1 x Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250B/EU) £89.99
1 x Asus H81I-Plus Intel H81 (Socket 1150) DDR3 Mini ITX Motherboard £58.99
1 x Phanteks Enthoo Evolv ITX Mini-ITX Chassis £41.99
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD38G1600HC11DC01) £39.95
Total : £781.86 (includes shipping : £12.50 Ex.VAT).
With a 250Gb SSD
Thanks squire.
It's just a first look at things for him. He wants a small case like the one I posted up. The height of the case is paramount. Needs to be small hence looking at the micro size setup.
If it's small case then for getting rid of heat, a non "k" i5 cpu would be doable too. I doubt he'd overclock it. I'll be building it for him and if the non "k" i5 can let the GPU stretch its legs then no problems there.
Didn't see thee 290x for less than the 290...good spot.
Budget was 600 but I'm struggling to do a setup that would be suffice for that price.
If he can get a mobo/cpu/ram/ssd and case as new then he'd take a second hand MM gpu no problems to cut the price down.
Main thing is to fit it all in a small form case. Might need to go back to get measurements from his livingroom and see what cases I can work with.
Stulid can you spec me up another mini build
CPU
CASE - THE ONE I WANTED CUBIX ONE
RAM
MOBO
250gig SSD
PSU that would power a 290 card
Any way of getting a £450ish budget - cpu isn't going to be overlcclocked
Bitfenix Phenom Mini-ITX Black Chassis & Xigmatek Maverick 600W 80+ Bronze PSU Bundle Bitfenix Phenom Mini-ITX Black Chassis & Xigmatek Maverick 600W 80+ Bronze PSU Bundle £79.99
(£66.66) £79.99
(£66.66)
Gigabyte Z97M-DS3H Intel Z97 (Socket 1150) DDR3 Micro ATX Motherboard Gigabyte Z97M-DS3H Intel Z97 (Socket 1150) DDR3 Micro ATX Motherboard £77.99
(£64.99) £77.99
(£64.99)
Crucial BX100 250GB SSD SATA 6Gbps 7mm Solid State Drive (CT250BX100SSD1) Crucial BX100 250GB SSD SATA 6Gbps 7mm Solid State Drive (CT250BX100SSD1) £68.99
(£57.49) £68.99
(£57.49)
TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED38G2400HC11CDC01) TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED38G2400HC11CDC01) £47.99
(£39.99) £47.99
(£39.99)
Raijintek Aidos Direct Contact CPU Cooler - Black Raijintek Aidos Direct Contact CPU Cooler - Black
Would this motherbaord fit in the case?
