small itx build for steam os streaming build budget £300
19 Aug 2013
hi there all
as the title says im looking to build a itx machine to plug into the tv downstairs to stream from my main rig in my pc room upstairs.
my main rig consists of the following
i7 3770k 4.5ghz
gtx 970
samsung evo 850 250gb
segate baracuda 3tb
16gb hyperx memory 1600mhz
evga 850w gold g2
coolermaster nepton 280l
corsair 540air
now my tv downstairs is a panasonic 42et5b, it runs at 1080p 60hz.
now i have a 64gb ssd that i have created a 32gb partition in fat32 and have placed the steam os download onto so thats out the way so all i am after is the
itx case
cpu
itx mobo
ram
small but decent psu
as far as the case goes i do not want anything too big as it will mainly sit upstairs and come down only when i get some free time on the tv so im looking for somthing to easily carry about. im looking to spend up to £50 on
the cpu im unsure what is the best to handle the stream. would a intel duel core or amd apu be better as its a cpu and decent gpu for the task
mobo
good bang per buck
psu
not sure what wattage to go for but will not skimp on psu
ram
any 4gb 1600mhz
hopefully that will help and i look forward to seeing what great specs you can come up with :)
Case- Element Q.
If they had a slightly taller one (for the dual slot GPU power connector) & a 2 slot I would so want to buy it... It would be such a great Lan party case if it had 2 slots....
have you looked at AMD kabini processors? very cheap to build. I have a 5350 with 4gb ram and an ssd inside an Akasa crypto case with 80W external power supply. should handle steam streaming no problem
Asus H81I-Plus Intel H81 (Socket 1150) DDR3 Mini ITX Motherboard £58.99
Intel Pentium K Anniversary G3258 Socket LGA1150 Processor £55.99
Silverstone Sugo SG13B-Q Mini-ITX Chassis - Black £36.95
Corsair VS 550W '80 Plus' Power Supply (CP-9020097-UK) £35.99
Kingston HyperX Fury Blue 4GB (1x4GB) DDR3 PC3-10666C9 1333MHz Single Channel Kit (HX313C9F/4) £26.99
