small oem question
19 Feb 2007
Sol
Im about to install vista oem on my girlfriends machine and im just wondering what parts i can replace without having to buy a new license, i know if i replace the mobo then i have to replace the license but is there any thing else i cant replace without having to buy another license or is that it ?
Thanks in advance
Only the motherboard, change this and you will require a new license.
If the motherboard fails under warranty and get a replacement then you can use the same license.
Rob
The only component swap that requires a new license is the motherboard.
You may still have to call up for activation after any other hardware changes - however they will reactivate you over the phone.
