Hello all,
My pc is getting on a bit now the specs are in my signature. I am looking to upgrade to a new PC as mine now struggles with most new titles. I pretty much do a little bit of everything in terms of workload but nothing seriously heavy at the moment.
I am really stuck on what to choose to be honest or if i should wait a little longer for the AMD refresh before i decide. I am uncertain about staying on DDR4 although I don't think it will matter too much for the near future but i think it may become an issue once DDR5 is utilized and more optimized over the next few years.
I would prefer to go AMD and originally was eyeing the 5800X but due to Intels new release the 12600/700K becomes more compelling.
I am wondering if its worth just buying a cheap mobo, cpu, memory etc now and just re-purposing my old case as it is still okay to use. To then maybe do a full system upgrade including a GPU in 2-3 years time.
or should I spend more money now on the same said items to have a fresh build and just update the gpu later.
Budget ideally max would be about £1000 (this would include CPU, MOBO, RAM, SSD, CASE, COOLER) will be using PSU, GPU, Soundcard, WIFI from old machine.
My basket at Overclockers UK:
Usecase: Gaming, Music Production, Light Photoshop/Video Editing & Coding is the workload. I also stream from time to time.
- 1 x Lian Li Lancool 215 Midi-Tower ARGB, Tempered Glass Black= £79.99
- 1 x Intel Core i5-12600K 3.70GHz (Alder Lake) Socket LGA1700 Processor - OEM= £244.99
- 1 x MSI MAG Z690 Tomahawk WIFI DDR4 - Intel Z690 DDR4 ATX Motherboard= £259.99
- 2 x Crucial Ballistix RGB 16GB (2x8GB) DDR4 PC4-28800C16 3600MHz Dual Channel Kit= £74.99
- 1 x WD Black SN850 500GB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS500G1X0E)= £59.99
- 1 x EK Water Blocks EK-AIO 240 D-RGB All In One CPU Water Cooler - 240mm= £92.99
