Small, Portable, Lightweight Laptop (12")
To be honest I wouldn't touch either of those with a barge pole, particularly for an ultraportable I'd only go for the big corporate manufacturers. Out of the two the samsung is the one I'd choose if I had to but it's stupidly heavy, the Dell 1330 you mentioned at the start is lighter and probably better...
Hmm, it's interesting you say that. Why exactly, do you think the quality of the Samsung and OcUK models won't be up to scratch?
I'd like to get the Dell--for one due to its customisability--but I'd really rather get one with a 12" screen I think. Plus it's only 150g lighter than the Samsung with a 4 cell battery, so I imagine would be pretty similar in weight with a 6 cell. The Samsung isn't that heavy, is it?
Without wishing to do a dis-service to OCUK, I wouldn't touch a laptop that wasn't from a big name manufacturer. I've seen the difference in build quality between companies like Rock and Dell/HP over time and particularly for an ultraportable (going to get thrown around a lot, spend half the day being carried around in a bag etc) I'd take the big names any time.
Samsung are almost in that league for build quality, they're not too bad at all, my dislike stems purely from the slightly plasticy machines (they look great, until you get up close) and not being terribly impressed with spec vs. weight.
I agree about the 12" screen, it makes a difference over the 13.3 in terms of how easy it is to carry round. I disagree about the weight though, I went from a Sony SZ to a Dell D430 as my work laptop, thats 13.3" 1.7KG to 12.1" 1.1KG, the difference was huge, partly down to the screen size but I think the weight matters too. In my opinion the 1.7KG bracket is pointless, either go really light and get a sub 1.3KG ultraportable or get a 2KG 14.1" machine.
Hi,
The samsung Q45 has just been replaced with the new Q210 Model and is the unit u should go for for value for money:
2 specs in the UK right now first one is around £570:
Processor - Intel Core 2 Duo T5750 / 2 GHz ( Dual-Core )
RAM - 3 GB (installed) / 4 GB (max) - DDR2 SDRAM - 667 MHz ( 1 x 1 GB + 1 x 2 GB )
Hard Drive - 320 GB - Serial ATA-150 - 5400 rpm
Operating System - Microsoft Windows Vista Home Premium
Screen - 12.1' TFT 1280 x 800 ( WXGA )
Optical Drive - DVD±RW (±R DL) / DVD-RAM with LightScribe Technology
Graphics - NVIDIA GeForce 9200M GS - 256 MB
Bluetooth - Yes
Notebook Camera - Integrated - 1.3 Megapixel
Warranty - 1 year warranty
Second is around £650:
Processor - Intel Core 2 Duo P8400 / 2.26 GHz ( Dual-Core )
Bluetooth - Yes
** EDIT OOPS just saw a post above has this laptop but only one of the specs not the cheaper one. I think I would go for the samsung over the titan very similar performance better graphics and better battery on the sammy and cheaper but the titan does have the faster HDD**
Cheers,
Hugest
Hi,
Bluetooth - Yes
Bluetooth - Yes
** EDIT OOPS just saw a post above has this laptop but only one of the specs not the cheaper one **
Cheers,
Hugest
But it weighs a ton for a 12" laptop, I mean did they leave a brick in there when they put it together? Most 13.3" laptops are lighter than that, it's only marginally less than a macbook.
