Small server build issue
1 Mar 2018
Hello, I hope you are well.
So I'm trying to build my 1st Plex Server but looks like I've encountered an issue already.
For some reason I'm unable to get any display when connecting monitor.
The components:
Motherboard : Gigabyte C246M-WU4 Intel XEON Micro-ATX Server
RAM : 1x Samsung 16GB DDR4 2133MHz ECC Registered Server Memory - M393A2G40DB0-CPB
Storage : 1TB WD Blue 3D, M.2 (2280)
CPU : i5 9600k
PSU : Corsair HX850i
GPU : Asus GeForce GT 710 1GB
I know some of the components are very low grade just managed to find them across multiple builds.
I've connected the GPU onto another system and used "DVI-D" input which works fine. Display works.
I've checked the PSU there is a button for "Test Fan" when pressed the fans starts rotating so that works.
I've connected the 1x RAM stick on each slot, one-by-one
Someone please help me out. I would really appreciate it.
It sounds like the motherboard is set to output video using the integrated graphics rather than the GPU. Try connecting to the display outputs on the board, you should then be able to change it in the bios.
Hey mate, thanks for reply.
Sorry I forgot to mention I've also tried this option yet still no hope for me :(
I don't think that mobo supports registered dimms, only udimms - so maybe just chuck some regular memory in it (that i5 processor can't make use of ECC anyway).
