Small speaker cable
26 Oct 2002
Norwich
I am after some speaker cable for my rears and it will be going either under the carpet or behind skirting boards.
Cat5 is out of the question due to size but wondered if anyone had used some thin cable they can recommend. Using with Quad speakers and fronts currently use silver based cable. Dont want to spend to much as do not buy into expensive cable making much diff or rear effect speakers.
Thanks in advance.
