- 22 Sep 2005
- Manchester
Hey guys im after a hard drive to window mod and put facing outwards in the front of my PC.
normal 3.5'' HDDS are just ... and i mean JUST too ong to fit ( cant plug em in without killing my caase)
so...
are there any SHORTER hard drives out there? cant seem to find any basic measurtments of laptiop drives
Rick
so...
Rick
Basically all laptop hard drives are almost exactly the same size so you are looking at 10cm end to end plus you will need a 2.5" to 3.5" adapter so that you can use the ordinary IDE cable which will add a bit. Hope that helps
