Maybe it has caused a problem, this problem, and the puddle had nothing to do with it?I’ve always done it that way it hasn’t caused a problem, no need to put it into reverse it will roll back a few meters just fine then into drive.
No I've been putting it into neutral and letting it roll back a few metres for 3.5 years and used to do the same with my old Smart. Never had a problem, its definitely to do with the big puddle splash.Maybe it has caused a problem, this problem, and the puddle had nothing to do with it?![]()
Lets give them a chance first.all people dont hate them , we just feel you shouldnt get your hopes up as they may be dashed (out of experience)
Other than possible bodywork damage, I can't think of anything that a puddle could affect that would cause a noise. And even if it was, why would it do only when rolling backwards in Neutral?No I've been putting it into neutral and letting it roll back a few metres for 3.5 years and used to do the same with my old Smart. Never had a problem, its definitely to do with the big puddle splash.
They aren't necessarily any worse, but they aren't necessarily any better either.Why does everyone hate main dealers so much, yes they charge double per hour labour what other garages charge but apart from that they can't be any worse can they?
Presumably you've tried reversing down the same slope to see if it makes a noise still?
The downside can be that main dealers are constrained by their diagnostic process, so even if you get an experienced mechanic rather than a "fitter", they often aren't allowed to do anything off script to try and resolve an issue.
Independents usually don't have such problems, and in some cases come up with better ways of doing certain jobs (e.g. fixing a component rather than replacing a whole assembly as a dealer would), or have certain "shortcuts" they have learned whilst doing the same repair that a workshop manual does not tell you.
I presume you didn't read the results of my google search?Other than possible bodywork damage, I can't think of anything that a puddle could affect that would cause a noise. And even if it was, why would it do only when rolling backwards in Neutral?
I highly doubt it’s just a coincidence. I did get a rough sound immediately after driving through the puddle but that went away the next time I drove it. Now it only does when in neutral and rolling backwards.Apart from the fact it's now making a funny noiseHitting the puddle may have had nothing to do with it and it's just finally worn/damaged something enough to make noise.
Most of which have nothing to do with either DCT equipped vehicles, or owners who insist on rolling back down a slope in Neutral?I presume you didn't read the results of my google search?
https://www.google.com/search
Plenty of accounts of strange noises after going through water.
Last time I drove it I went into a big car park and put it into reverse a few times, the noise was either not present or not as bad.Does it make the noise when actually reversing down the slope?
Well they collected it this afternoon instead of tomorrow, I put it into neutral and let it roll back to make sure the noise was still there and it was. Now the anxious wait.I’m going to get the delivery driver to put it in neutral and let it roll back so he can hear it.
You were spot on, a piece of the plastic under tray has broken off and is causing the rubbing. They are delivering the car back to me and ordering a replacement part. They’ve temporarily removed it so it doesn’t make the noise.Could be something as simple as some plastic trim under the car dislodged and rubbing when you go backwards?
Yep easiest £86 they've ever earnt I should thinkSeems it was an easy one for them to diagnose after all.
I'm sure you could. Likely if you'd have lay down on the ground with a torch and looked underneath the car you would have seen some damaged plastic.No way I could have figured this out by myself
A quick look suggests the undertray comes in 3 parts and is just held on with screws - only a matter of knowing the age of your car as to what to order. In this day and age there are youtube videos showing you how to do easier jobs like this.and no way I would know what part to order or how to fit it.
You could have temporarily (or even permanently) removed it yourself, or given it's underneath the car and out of sight, probably repaired it with cable ties or similarYou were spot on, a piece of the plastic under tray has broken off and is causing the rubbing. They are delivering the car back to me and ordering a replacement part. They’ve temporarily removed it so it doesn’t make the noise.
I'd imagine at main dealer prices, probably around £200-£300They will let me know how much it’s going to cost in due course.
I blame that damn puddle and the fact that I didn't see it until I'd gone through it like a river.Yep easiest £86 they've ever earnt I should think![]()
