Yeah constant tech visits recentlyYou seeing more comms hub dropouts at the moment? We have seen a bit of an uptick on commshub reboots /power cycle jobs
Thanks, just DM'd you. They've been chasing the DCC team since mid-May according to my replies on TwitterSeems they raised a ticket with the DCC, i can get that checked for you if you DM me your mpan
Your meter and IHD should be all up and running now.Thanks for this, I'll PM you shortly, once I've located the MPAN number.
Seems like the DCC (third party company) has done nothing with it. Got the ball rolling though so see what happensThanks, just DM'd you. They've been chasing the DCC team since mid-May according to my replies on Twitter
The Telefonica area specifically appears to have a major issue with power cycle (blackout/powercut/low power variance) issues, so when the power drops the Comms hubs go into panic mode rather than a low power state to save energy. They are apparently releasing a patch to all comms Hubs soon but it's got to be tested to an inch of its life before they will let it go live environment just incase it sends the whole network into a panic loop.Comical that i mentioned comms hub dropouts to @BigBoy and then your issue is a comms hub communication issue![]()
The meters are not the issue the communications on the other hand are a world unto them selves!Are smart meters still causing issues then?
We got solar installed at the moment we still got an old school electricity meter.
To get an export tarrif we would need to get one installed, but for the sake of maybe £30-£40 a year I don't know if it's worth the hassle.
Yeah this ones telefonicaThe Telefonica area specifically appears to have a major issue with power cycle (blackout/powercut/low power variance) issues, so when the power drops the Comms hubs go into panic mode rather than a low power state to save energy. They are apparently releasing a patch to all comms Hubs soon but it's got to be tested to an inch of its life before they will let it go live environment just incase it sends the whole network into a panic loop.
By old school - do you mean the type that can run backwards?Are smart meters still causing issues then?
If you are having a solar PV install you must upgrade your meter or you will get no feed in at all.Errrr, no I don't think it does.
It's got a little mechanical disc, that clocks up little numbers that rotate around, like a scoreboard or something.
But I'm fairly certain (although I've seen the spinning disc go backwards) it doesn't start deducting from the total, shame.
I'm pretty sure that won't have a backstop. You need to get that changed asap. Give your supplier a call - they'll be out pretty promptly to replace it.Errrr, no I don't think it does.
Exactly this am at work or would have linked this myself.I'm pretty sure that won't have a backstop. You need to get that changed asap. Give your supplier a call - they'll be out pretty promptly to replace it.
For info... https://www.which.co.uk/reviews/fee...tricity-meters-running-backwards-afQO90P1oLps
Note the part about being billed retrospectively if you get caught.
The spinny disc is a time keeping or measuring device it measures flow into the meter from left to right so cannot measure outgoing supply. The reason they should be upgraded to a more modern meter is 1. They have no backstop so potentially can cause them to read incorrectly when pulling from the grid. And 2. They have no way of recording passage out of the meter, meaning any generation out output it loss and cannot be tracked.It doesn't reverse the numbers, or the bill reading, at all.
I checked we left the house for several hours during the day with nothing on, when we came back the reading hadn't moved (as expected the solar should have covered all tick over) but certainly the numbers were not lower.
I think the little spinny disn thing is like an indicator rather than affecting the actual reading.
Either way, best to give your supplier a call and notify them of the PV installation and let them know you've got a mechanical meter. If they're notified, it's them up to then to update it.It doesn't reverse the numbers, or the bill reading, at all.
