Smart Plugs
Just make sure the rating is correct for the appliance or appliances you wish to control, some are only rated for 10amps draw and things like heaters may well draw more.
Aye, if it's a 10A device, I wouldn't want to run any more than a 2kW heater. In fact, I'd never use any of these for any kind of high power devices. The two Hues I have with dodgy relays have only ever been used at low current but they still went sticky after a couple of years.
I use one for the lamp in the living room for the dog, pops on at "sunset" so changes throughout the year. Can also set it to come on randomly between two times in the ven when you're on holiday so pretend that someone is home etc. TP Link one, I've had for about 6 years now.
Tapo is reliable and works well with Alexa and Gogol stuffs. I've been using a combo of the Hue Smart Plugs, Tapo and Meross plugs at my place for years. Just be sensible with what you plug into them.
Hue is the most reliable (obviously as it is part of the Hue ecosystem), with Tapo and Meross close behind. They've all got their pros and cons.
Hue smart plug is a fat wideboy whale and often takes up an adjacent mains socket due to its size, if used on an extension lead. Like anything Hue based, price and availability are an issue.
Tapo I've had no functionality issues with, but works at its best if you utilise it with its spyware app. These are also large plugs lengthwise but do not plug adjacent sockets. They're on sale almost every day somewhere.
Meross MSS110 (wifi) is the smallest plug I have and like the Hue plug ties into Homekit, which I prefer over Alexa/Google. Does its job perfectly.
Hue and Tapo plugs I've had for 2-3yrs+, with the Meross being the newest. All 3 I find reliable and I use them for switching on the Christmas Tree, Energy monitoring my NAS, switching on the PSU's for my laptops and switching on various USB charger hubs as I don't like leaving these on 24/7.
I do have a Matter plug from Onvis but it has oddly been rather unreliable, which is a shame because I use their matter motion sensors that are flawless. I wish there were more Matter based plugs that just worked reliably so I don't need to faff with software.
A point worth noting if you are in the apple system. To control ios ones from outside your house requires some sort of server in the house, which can be an appleTV or and ipad.
I use Shelly Smart Plugs. No hub required and can be controlled via bluetooth and wifi. They can also act as wifi extenders (Although I dont use that functionality) and have power monitoring.
Quite reasonably priced for the features they offer. I like them as I also use other Shelly products (Relays, Energy Monitors etc)
Bought a 4 pack of the Tapo energy monitoring ones at Black Friday. I don't have many appliances that require remote switch on/off, but it has been useful to see the energy use of various things, such as TV (no where near as much as I thought at ~100W inc speakers and sub (LG G4))
Does make me wonder how my smart meter is reading what it is at the end of the day based on the main usage of electrical appliances in the house too.
I've had about 5 different manufacturers over the years from the original amazon ones, to the tapo ones and very cheap chinese ones. I've never had an issue with any of them other than some having to have very strong wifi signal to initially connect during setup.
I try to always buy the ones with power consumption monitoring built in now as that comes in handy over time as you can build up a picture of usage for certain appliances. Like for example, - geek mode now - my dishwasher has eco mode program which lasts 4+ hours, and an intensive mode that lasts 1hr 40 minutes. Which one uses more electricity I hear you ask? Well... actually they are very close, but eco uses loads less water so I am told by the manufacturer. Things like that...
I also use them for saving money by turning things off and on with schedules like the hot water tap, server, desk lights, shed lights, xmas lights, other lights, shed electric heater. With the stuff that are lights, it's convenient also to just be able to ask alexa/google to turn on or off a light or turn all lights off.
I'm surprised it's not hard-wired either. @dlockers
It's a special propane filled model you can install yourself. 3 pin plug into its own circuit.
Electriq easy install from appliancesdirect
Edit: it's absolutely brilliant and I wouldn't hesitate to recommend it. I think I paid 800 quid. Vs a proper split with a bonkers 1500 installation only cost
I've been using TP plugs for a few years, so far no problems with them at all.
I don't use them particularly heavily, mainly for things like christmas lights and lamps but they're in regular use and at around a fiver a go when you get a 4 pack on offer it's not a huge cost if they die after a few years.
Nice! Never even knew these existed, in the time we've needed AC we were battling with those rubbish portable things. Will definitely be considering one of these if the need arises.
Things that run for a long time/continuously add up a lot more than things that use lots of power on the dial IME. Check your idle usage, consider fridges during on cycle etc.
Your TV draw will vary hugely also - when I tested a 55" OLED I had consumption between 69W to 240 depending on SD, HD and HDR content (and what the content was). Amazingly adverts draw more than normal TV because of all the bright colours!
Got a link to the model you have? Genuinely interested if there's an in-between of a fully installed system vs a portable.
I assume it still has an external compressor, and requires the necessary ducting?
They usually come as 2 halves, and once you connect the piping between them, there a valve to open that releases the pre-filled refrigerant from one section into the full loop.
It's absolutely at that intersection. It's still a big boy unit with external compressor etc.
Still first fixed ATM as I need to put a pad! But then it'll be directly under the waterfall roof so I need guttering. Just not enough hours in the day lol
... so what have running costs been on days you have used it as an office ... do you precondition.? (ie. on cheap octopus energy .. syncing it with Igo maybe even better)
e: (: sticking relays .. I'd be opening canister to see whether contacts are pitted/blackened - maybe clean with some wet&dry as I did for espresso machine)
