Smartdoctor? Fan Controller
21 Oct 2006
OK before you all say " smartdoc is Fully star out swearing please. use afterburner" please read on.
I want to use smartdoc, but it will not install.
I like the way you can set smartdoc for the fan speed to increase at 4 different temps, which can also be set by me. ie 40c = slow 45c= medium 50c=fast 60c=faster. Or what ever temps you want.
? Is there an other software i can custom the graphics card fan with, that has the same feature as smartdoc?
I'm not interested in overclocking it.
It does? Oh. Looking at the info i had it could only be set to 2 setting. 40% @ 50c or after 50c it goes to 100%. Or which ever temp you chose.
Must have some duff info.
Thanks
Thanks
I always used Sapphire Trixx utility, never tried Afterburner, but when I crossfired my cards I couldn't set separate fan speeds for each card, so with Afterburner I could do that and set custom fans for higher temps, great utility.
Thanks
Settings>Fan>Make sure to tick the "Use user define etc.." then set the ratio you want :)
