Smoothwall vs draytek 2830 firewall
30 Jul 2003
Hi there peeps,
quick question, I'm dealing with a clients old IT company who are adamant that Smoothwall is far superior to the firewall that comes wuth the Draytek 2830 routers and want to keep charging the customer to "rent" it to them and are scaring them with claims if we remove it it will compromose their security etc.
I thought i would get another view on it, i mena the newer drayteks are using object based rules etc to make life easier now, and I've never had any security issues so far with any of the routers i have sold.
penny for your thoughts? :)
I would have thought that the Draytek would be good enough (I use them).
I’ve also used Smoothwall, but this was back when SME routers were much more expensive and re-tasking an old PC made financial sense.
If the old IT company are that sure about it then they should be able to detail at least one exploit that Smoothwall blocks and the Draytek doesn’t.
Having used Smoothwall I find that it is quite good and has many options within the firewall, proxy and web cache, what scale of site are we talking though surely using a Draytek I would expect it would be cheaper to buy a dedicated hardware firewall as a one off fee!?
its 15 computer 1 server standard small business enviroment, i mean i could get a sonicwall, but that might be overkill tbh and they dont really want to spend that much money, so im thinking the newer 2830's are a good mid ground :)
