SMP collection and assignment servers down?
11 Oct 2006
Wiltshire
The SMP collection and assignment servers seem to be down at the moment. I've got three clients unable to pick up new work, one of them also unable to upload, and I'll have a fourth in half-an-hour. :confused:
One of the standard clients on my X2 has been trying to return a WU and get a new one since about 10:30 this morning. Got about 3hrs till the Quad finishes its current work so if it's still failing it'll be time for some more overclocking I guess :p
Well my standard client just picked up a new WU after restarting - seemed the PC just needed a reboot as attempting to run anything came up with a message saying I was out of RAM.
Not long till the quad finishes the first of two SMP WUs so will update this then :o
still down, its trying to connect to 0.0.0.0. when the servers are back up will it submit ok or will it need a restart?
I would keep the clients running - they will connect eventually and it's safer than risking losing your completed WUs, I only restarted my standard client as it seemed to be a problem with my PC rather than the servers (which it was).
You are being assigned to 0.0.0.0 by the assignment server as it doesn't have any relevant work for you, once it can see a work server that suits your requirements it should point you that way - it's working exactly as it should (just could do with some extra SMP servers to lighten the load) :o
Looks like they came back online in the early hours of the morning. I had 4 queued up but they were all working when I got up at 05:00 local time (03:00 GMT) and RDPd into my main rig. Looks like none of mine were waiting more than about 3 hours which isn't too bad.
Yes, 171.64.122.76 isn't* accepting completed WUs. I've got two waiting to go to it. 171.64.65.64 seems okay however.
* possibply "wasn't" as it's shown as 'accepting'. We'll see at around 23:00 when my two WUs should try to upload again. I might be asleep though...
