So how does this sound..
Hey man, that build looks really awesome. :D
I was thinking of doing a similer setup.
I have a couple of questions though if you don't mind me asking.
1.) How did you remove the optical tray/cage thing? Mine looks like its riveted on.
2.) Also what did you use to cut out the top panal for the radiator?
Hey :)
I drilled the rivets out, took about 5 seconds per rivet and is really easy. You need a drill bit that matches the size of the rivets.
I used a dremel for the top panel and if I'm honest the cut isn't perfect hence why I use a grill to cover up the rough edges. Once all these bits arrive i'll strip down the system and do things better :)
My plan at the moment is to mount both the pump/res combo in the lower section on the foam block and remove the middle shelf.
That or I use some bulkhead connectors to go through the middle part.
Only thing is my plans include another 360 rad in the bottom and want to make sure I leave enough room for it.
Much better :)
Window panel
Still need to sort out a mount for my SSDs though
