I was just a little worried, as the side panel (the one without the fan) seems to just be held shut by the screws. It says that it swings open in the book, but it is bending slightly outwards in the middle. It this normal?
It is holding a few cables back (that's what is pushing it out).
If you didn't understand the above - I have to push the fanless side panel to get it closed, and then put screws in to hold it in place. Should it be like this?
